Help wheel balancing nightmare Beeep ABS and Break light flashing
OK I need your help, I have had a wheel wobble at between 55 and 60 which is classic wheel balance issues. So today I took the car to have the wheels balanced and the tires rotated, on the way back from the garage and took the car for a run at between 55 and 60 to see if the wheel wobble had gone.
Well the wheel wobble appeared to have gone but there was a awful vibration though the steering wheel and then when I was coming off an exit a beep sounded the ABS was on and BREAK light was flashing.
any ideas what could be the cause? i don't believe in coincidence and I had just come back from having the wheels balanced so I am guessing that it is something to do with that or could I be wrong.
many thanks
James
many thanks
James
My brake light flased because my brake fluid was low. Check that. Other things have happened to other people to cause that but I don't know what they are. I'm unsure about the ABS I keep having the esp kick off on it's own.
james0013
10-21-2008 08:38 AM
