High current draw when ignition is off, drains battery.
Car:
02/03 Audi A6 Avant (4B, C5) 1.8 T quattro manual trans.
Problem:
Battery goes flat over night.
Findings:
This list of fault codes looks frightening, but the information panel between the odometer and speedometer says OK. So to the unknowingly, everything seems OK.
Problem:
Findings:
- Battery voltage at rest, charged: 12.6V
- Alternator Charging voltage: 14.2V
- Current draw (measured via negative battery cable to negative battery terminal) when ignition is off: More than 2A.
- Excess current draw ceases when fuses 15 (Kombigerat, Klimaanlage) and 37 (Telefon, Radio) are pulled.
- When ONLY fuse 15 is pulled, the current increases is a pulsing manner, almost like when engaging the turn signal.I don't know if this is normal behaviour.
Code:
VCDS Version: Release 11.11.5 (x64) Data version: 20121222 Sunday,05,May,2013,10:00:22:39271 Chassis Type: 4B - Audi A6 C5 Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67 75 76 77 VIN: WAUZZZ4B83N004654 Mileage: 116150km/72172miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-906-018-AWT.lbl Part No: 4B0 906 018 DC Component: 1.8L R4/5VT G 0001 Coding: 11702 Shop #: WSC 02325 VCID: 65C16926FFF8A130B2A WAUZZZ4B83N004654 AUZ7Z0B2163064 1 Fault Found: 18010 - Power Supply Terminal 30 P1602 - 35-00 - Voltage too Low Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4B0-614-517.lbl Part No: 4B0 614 517 H Component: ABS/ESP allrad 1728 Coding: 06275 Shop #: WSC 00000 VCID: 26432E2AC27E6A287B0 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl Part No: 4B0 820 043 AD Component: A6-Klimavollautomat 0105 Coding: 00000 Shop #: WSC 02325 VCID: 5CB74CC2CCB2E0F81D4 3 Faults Found: 01592 - Air Quality Sensor (G238) 57-00 - Electric Circuit Failure 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01206 - Signal for Duration of Ignition Off Time 27-00 - Implausible Signal ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI84.lbl Part No: 4B0 959 655 P Component: Airbag 8.4EP 2002 Coding: 0000706 Shop #: WSC 02325 785 00200 VCID: 3D71E14667E8C9F00AA 3 Faults Found: 01044 - Control Module Incorrectly Coded 000 - - - Intermittent 00592 - Seat Belt Switch; Passenger (E25) 000 - - - Intermittent 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-920-xxx-17.lbl Part No: 4B0 920 933 N Component: KOMBI+WEGFAHRS. VDO D11 Coding: 00144 Shop #: WSC 00490 VCID: 2E53D60AEA8E2268830 WAUZZZ4B83N004654 AUZ7Z0B2163064 3 Faults Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent 01304 - Radio 49-10 - No Communications - Intermittent 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 4B0-962-258.lbl Part No: 4B0 962 258 L Component: Zentralverriegelung D37 Coding: 06721 Shop #: WSC 02325 VCID: 326BC27AFEB60688E78 5 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal too Low - Intermittent 01559 - Drivers Door 58-10 - Can't Lock - Intermittent 01559 - Drivers Door 59-10 - Can't Unlock - Intermittent 01560 - Passenger Door 60-00 - Won't Safe 01559 - Drivers Door 61-10 - Won't De-Safe - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl Part No: 4B0 035 192 K Component: RNS 4.2 H06 BNO 0102 VCID: 25412926BF78613072A No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00050 Shop #: WSC 02325 VCID: 040754A214827838054 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl Part No: 4B0 035 192 K Component: Radio BNO 0001 Coding: 00207 Shop #: WSC 00490 VCID: 25412926BF78613072A No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4D0-919-146.clb Part No: 4D0 919 146 B Component: TV Tuner H08 0805 Coding: 0000010 Shop #: WSC 02325 785 00200 VCID: 285F2012986A7C5849C No fault code found. End ---------------------------------------------------------------------
Follow-up post:
I ended up purchasing a new battery, which I installed 13th of May 2013. I deleted old fault codes and started using the car as normal. After this I have not been able to reproduce the problems as described above. Problem solved, actually. I would never have believed that an old battery would cause these kind of problems, but it seems like this actually was the case. In the future I will be less reluctant to buy a new battery when the car fails with similar symptoms...
I had the same thing happen with my 1998 A6 2.8 30v. The battery was draining, tested ok. I thought it might be the hood switch, but then left it at auto parts store for a day to drain and trickle charge, it tested bad. Replaced battery, no further problems.
the same thing keeps happening to my battery it drains over night when the radio fuse is in. I got the battery tested yesterday and they said the battery was good but this morning I went to crank the car to go to work and the car would not start
intergalactic
03-05-2012 09:42 AM
compman723
06-13-2011 09:59 PM
salinas
12-11-2007 08:09 PM
