High frequency vibration through steering wheel?
Old Oct 28, 2010 | 09:13 PM
paludi's Avatar
Default High frequency vibration through steering wheel?
Does any have any experience with a high-frequency vibration that seems to develop as the car warms up? It is most noticeable through the steering wheel and while turning.
Thanks in advance.
'02 A6 3.0 with Triptronic 130K on the clock
Old Oct 29, 2010 | 09:13 PM
Jackmup's Avatar
If it happens when you apply the brakes it is your most likely brake rotors.
If it happens only when your turning or get worse when you turn have your front CV Joints inspected.
If it does it all the time check your tires for Flat Spots (broken cords) or improperly balanced and inspect you control arms.
Old Oct 30, 2010 | 07:53 AM
bob martin's Avatar
Tires, control arms, tie rod ends, shocks, barke rotors or CV joints. You have to get under there and look (or have someone who knows Audis do it for you).
Good luck. Mine still vibrates after replacing all of the above....
Bob
Crazy Dave
Feb 7, 2011 06:04 AM
paludi
Dec 26, 2010 09:03 AM
paludi
Nov 7, 2010 09:22 AM
shelbyturbo
Oct 23, 2008 10:48 PM
DominanceX
Jan 23, 2007 11:27 PM
