Hot rotor?
Replaced the passenger side, rear, caliper, rotor and pads and now it is VERY hot after even a short drive. No warning lights. I am worried that maybe the EPB is not disengaging. Can these get out of sequence?
Appreciate any suggestions. Thanks. 2005 Audi A6 4.2 Quattro Tip |
did you bleed the system? It sounds like your caliper is pushing the pad against the rotor
Brakes were bled-pedal height and feel is normal.
Originally Posted by twopedalwarrior
(Post 1511865)
Well obviously the caliper is pushing against the pad if its getting hot. did you not place the spring clip properly? or is the ebrake cable not adjusted properly?
