How do I use Sports mode on auto transmission?
How do I use this? Can I just switch over whenever? I switched it like 3 times from Drive while on the freeway, I wanna make sure I didn't f it up.
RE: How do I use Sports mode on auto transmission?
You just put it into S whenever you want to it won't damage anything. On the highway I don't believe it makes any difference if its in drive or S mode. But on regular street grounds it does keep the rpms higher then in D. Hope it helped
Does it use more gas up? Does it help with suspension/turning? Is keeping the RPMs higher a good thing? |
bump
Yes
Not sure but i don't think so Depends if you want better throttle response, otherwise you're wasting gas for no reason |
Please explain what increased throttle response will do?
well look at it this way in if your in D and you come out of a corner youll most likely be braking into/throughout the corner so your trans will be in 5th gear when u go to give it gas it will have to think to upshift to second or third gear for you to get proper acceleration ... now S will hold a gear till a little over 3000rpms so if your going into the corner Smode will keep your trans in a lower gear bc it is programed to keep the trans around 3000rpm and when your coming out of the corner you will still be in 3rd gear and when u step on it ull instandly swing out of the corner ... D is way more gas efficient i have found bc i drove in S for about a week and it ate all my gas ... i too was wondering if it was bad to keep the rpms up that high but i guess not(didnt want to start burning oil)
but increased throttle response doesnt really mean anything unless your racing or fooling around with another car or just having fun |
best way to experience the S is to put the car into S and slam on the throttle~ such a sensation... not on highway thro..wont make a difference, but if you are on roads with lots of throttle then brake then throttle again, you can realy tell the difference from D~~ but BE SAFE!
good mpg in sport mode
so today just driving around pretty empty streets at 35mph in sport mode I realised that my mpg was great as it was on cruise control but driving in a low gear till I pressed accelerator is it bad for the engine to be in such a high gear
