I cant seem to find it again
Old Mar 15, 2009 | 01:09 PM
SouthDakotaA6's Avatar
Default I cant seem to find it again
ok I have a 2001 a6 2.7t and the car when you hit the throttle a friend of mine says it looks like it is burning oil, but only when i really try to get up and go. I saw on the forum that it could be a rear cam seal or somthing but i cant find it now any help or ideas, by the way the nearest audi dealership is about 6 hours away> any help would be awesome
Old Mar 15, 2009 | 03:08 PM
auditech79's Avatar
If you have a burning oil smell, search burning oil smell. Most likely the valve cover gaskets and cam adjuster seals like you said.
Old Mar 15, 2009 | 07:33 PM
bob martin's Avatar
The friend of yours said it looked like it was burning oil from where? The tail pipes? The motor compartment? What did he see to make him think it is burning oil? Or, dud he just smell oil burning?
Old Mar 15, 2009 | 07:40 PM
here is a bit of a update when i was going about 55 hit the gas and got alot of white smoke out the tail pipes what seal would this be or what could it be
Old Mar 16, 2009 | 02:11 PM
ppgoal's Avatar
Burning oil is usually black or dark. I suspect that if you are running in cold weather and getting on the gas, you are seeing what is normal condensation. My car regularly puts out some light white "smoke" when warming up or when accelerating is cold weather, even when it's on the highway at high speed. I think if you do a search, you will find this normal.
After the car is warmed up, if the "smoke" smells heavily of gas, then you may be running too rich. Or if it is continuous and smells of antifreeze, then you may have a water leak (not good).
I suspect it will all but disappear in warmer weather. Unless you already be down south, in which case ignore my comments and start $aving.
Old Mar 16, 2009 | 04:31 PM
NH_USA's Avatar
What ppgoal said
Old Mar 16, 2009 | 04:38 PM
nemohm's Avatar
Burning oils tend to be bluish.
Old Mar 16, 2009 | 09:23 PM
a6hcw's Avatar
You could put the car on jack stands and look under the car for the oil leaks, as the oil will flow downward and sometime burn on the exhaust pipes or catalyitic converter. Too much oil and the car is toast.
mikees501
May 10, 2012 12:39 PM
b5audi1.8t
Apr 14, 2009 05:47 PM
auditurbo381
Sep 27, 2007 12:50 PM
Propagandalf
May 10, 2006 10:18 PM
