I just found a leak
I am the new owner of a 2000 A6 2.7T , 6 speed with 48,000 miles on the clock.
It appears that i need to replace the camhsaft and crank seals due to leaks. Does it make sense to replace the timing belt while I am there? Additionally, what other maintenance items should I take care of, i.e. water pump, tensioner, serpentine etc? I know it may be early due to mileage but does it make sense to leverage the labor cost at this time? Thanks in advance Al |
RE: I just found a leak
Yeah you might as well replace the timing belt and all the extras as you said.
while ur there i think u should. Better now then to do it later and do it all over again. Personally i would if i were u
may want to replace the snub mount also.
Thanks all
The guy I bought from had already replaced the snub mount. I just picked it up today so I will give it a good washing and post some pics Al |
I have the same issue --- is this a common problem with the 2000 2.7T?
How much did it cot to fix - head gasket and sepentine? |
yes it is a common problem with the 30V 2.8's and 2.7's also I would sudjest replace the water pump and thermostat while your in there to its just all preventive maintance
What was the cost - did you have a dealer do it?
