Inspection problem
Old Sep 15, 2008 | 09:09 PM
millenia's Avatar
Post Inspection problem
Hey guys, went to do my inspection today, didnt pass because when he tried to connect to my OBD it wouldnt connect, it said "linking error" what could be the problem???
Old Sep 15, 2008 | 11:09 PM
joetm's Avatar
im guessing something wrong with thier obd cord or something wrong with your obd port
check wire in the back of the port on your car or an easier solution may be to take it to anyone that has vagcom or another scanner and see if they can connect
Thatll tell you if the problem was at your mechanics shop or with your car
Old Sep 15, 2008 | 11:36 PM
oc_audica's Avatar
do you have an aftermarket radio/amp?
Old Sep 15, 2008 | 11:56 PM
millenia's Avatar
nothing after market, everything is stock
Old Sep 17, 2008 | 10:16 PM
jj2345's Avatar
i had that same problem,turns out only my obd fuse was out,i replaced the fuse and it worked
Old Sep 17, 2008 | 11:11 PM
millenia's Avatar
but obd fuses look alright, is there like another one under neath the dash???
CGrin
Sep 24, 2014 04:19 PM
foos
Mar 31, 2014 10:46 PM
audi guru
Aug 20, 2009 04:03 PM
brightside06
Nov 7, 2006 04:52 AM
young_un
Feb 15, 2006 03:31 AM
