it's driving me crazy!
has anyone had this problem? whenever i turn my wheel to the right, and it's cool outside, my parking brake light flashes and i get an annoying beeping. it drives me absolutely nuts. any help with fixing this problem would be greatly appreciated. thanks.
RE: it's driving me crazy!
i'm having the same problem with my 02 A4. when it drops below 70 degrees and i turn the wheel to the right the brake light beeps and blinks, but when i turn the wheel back to left it resets the light. this is driving me nuts, did you ever find a solution, i was told either the brake fluid is low or the brake pads need to be replaced. thanks for the help.
If its the red brake lamp that illuminates your either low on brake fluid or the float inside the master cylinder is bad, in which case you would need to replace the resivior.
thanks for the help......filled the reservoir......hopefully it stops beeping.
