Just did my tranny drian/refill with filter change!
Went pretty smoothly. The only thing I messed up on was not installing new O-rings on the drain plug and fill plugs. Oh well, I reused the old ones and there are no leaks.
I drained about 5 and 1/4 quarts of fluid. At 113,500 miles, it was very dark, not black but like a very dark grey. The pan magnets were caked in grime and the old fluid smelt a little burnt. I've read that this means bad news but we'll see what happens. After changing out the old filter with new filter and replacing the pan with a new gasket, I refilled it with new fresh Pentosin. It took about 4 1/2 quarts on the first fill and then after running through the gears it took an additional quart of tranny fluid. Just about the same amount I drained. She seems to shift more smoothly from what I can remember....it's my wife's A6 so she'll let me know if she notices smoother shifting. Took me about 3 hours. I'll repeat the process in about another 1k miles but next time i'll only drain and refill. Cheers. |
I'll repeat the process in about another 1k miles but next time i'll only drain and refill. |
i wanna do this to my tranny but im not sure if i'll have problems with it..
Originally Posted by rsonistxl
(Post 1095449)
what year is your a6?
Originally Posted by madridlover
(Post 1095464)
IF you do it right i.e have the car level; drain when engine/transmission has cooled down, not hot not cold then you should be fine. I did it without using the VAGCOM and my A6 runs fine, shifts smoothly, and there are no CEL's.
Have just done mine last weekend for a second time in two months (not many miles though on the previous change) leaving the "new" filter in, and I will do it again in about 2000 miles, when I'll get in the second new filter. As Jim said, she should be good for another 60,000 miles...probably its life while I own it. IT CAN BE DONE W/OUT a VAGCOM, indeed, with POSITIVE outcome/results. |
Originally Posted by twinturbosixer
(Post 1095513)
Since you basically put in what you took out doubt there will be a problem. However You should drive it for the next week just to listen for anything out of the ordinary, God forbid it starts whining and your not driving it. I know my wife wouldn't hear it... Thanks to Audi Symphony!
