Sponsored by:
Sponsored by:
Just got a $500 '98 A6, no compression
Old 06-21-2017, 08:38 PM
Nirky's Avatar
Default Just got a $500 '98 A6, no compression
New to this forum The A6 ended up in my lap last week.
Seller (mechanic, owns shop) says the previous owner was driving and the car just quit on her. He said he measured no compression. I didn't ask if he did all cylinders or just one bank.
Timing belt intact.
Car will crank but that's it.
I'm thinking belt skipped some teeth and bent some valves?
If its bent valves, would you rebuild the head or just swap a used engine?
And if I do swap, I know the Passat also used the same 2.8 6, but what about looking for a wrecked Jetta, did they use the same 2.8 in those? Thanks in advance.
Old 06-28-2017, 04:48 PM
ppgoal's Avatar
I think you wasted $500 and you should part it out and minimize your losses. I do not think VWs used the same engines as Audi even though they are part of VAG. But before you do anything, run your own compression test and try and figure out what "broke".
Old 07-07-2017, 07:04 PM
Nirky's Avatar
Actually VW and Audi engines are the same...for example the 1.8 Audi A4 turbo engine is same as the Jetta 1.8 turbo. Not only that, the chassis platforms for those two cars are identical. Same with A6 & Passat. Audi TT & VW Beetle platforms the same also.
I do agree however with your other two points...pinpoint where the engine went south and either fix or part out. The car has 17" OEM alloys with good tires, so when I went in for $500 I knew I wasn't going to be losing money in the worst case part-out scenario, just may take a while to make my money back, and then some.
deckert4591
05-07-2011 06:41 PM
Dallas09
05-01-2009 04:41 PM
santana86
04-29-2008 09:51 PM
DriftnB5
12-22-2006 09:17 PM
fastmayte
01-30-2006 11:51 PM
Quick Reply: Just got a $500 '98 A6, no compression
