Key Programming
I tried some searching, but I might not be putting in the right key words. There was a post where it stated that you could program your key to lower your windows and also program the key to move your driver seat and mirrors! I appreciate your help! Thank you! OOOO |
RE: Key Programming
RE: Key Programming
Southboro.......You Da Man! Thanks!
Also, just to let you know, my turbos are fine! They are putting out around 20psi. It turned out to be my TBB! A very bad tear on the bottom! Go Figure! I went ahead and had my mechanic put in a new clutch, driver and passenger side upper control arms (passenger side would knock a bit if I went over a speed bump) and some Samco hoses. You know these cars are our babies! OOOO [IMG]local://upfiles/13659/F76644F5DC6F486980A17CC87E88731A.jpg[/IMG] |
