Knock in the steering. looking for cause
Old Aug 10, 2009 | 04:50 PM
KarlNapp's Avatar
Default Knock in the steering. looking for cause
Hi,
on my 2001 2.7 i heard a knock and some hauling sounds when i was steering my car in close circles to the left. So i found some play in the tie rod ends and replaced those along with all the control arms since they all came in a nice kit. Then i had someone make a few turns in the parking lot to see if that fixed it. But i still heard a loud knock at a very specific position of the steering wheel when wiggling it left to right a few inches.
So then i took a look what was going on and i saw that the part inbetween the tie rod ends, that bar that connects the two was moving up and down. Is it supposed to do that? What is the problem with my steering? How can i fix it? I wanted to get the car realigned after all these changes i made but now i think i am going to wait until someone here tells me what is wrong with my car.
Thanks for your help.
Kai
Old Sep 2, 2009 | 10:30 AM
aliyork35's Avatar
stering may not be working problem. rectify by giving to proper mechanics.
Old Sep 2, 2009 | 10:55 AM
dougal302's Avatar
Karl: Does your car have telescoping strg wheel? We found some very weird clunks and growls when we played with positioning on ours-so we found the sweeter spot that stopped them.... Just a thought..
Old Sep 2, 2009 | 05:28 PM
bob martin's Avatar
Karl,
What do you mean by "that bar that connects the two"? Do you mean the part covered by the bellows? That would be your inner tie rod ends. These go bad and need to be replaced.
What do you mean by "hauling" sound? Do you mean "howling" sound? That would be your power steering fluid level. Add some of the proper fluid (make SURE it is proper!!!) and that should go away.
Bob
Old Sep 2, 2009 | 10:38 PM
james0013's Avatar
Could it be your CV joints? check to see if you have a torn boot.
PoloBLK
May 29, 2011 12:46 PM
vlado182000
Jul 16, 2010 03:20 AM
chusaiyan
Apr 9, 2009 09:28 PM
diehlryan
May 27, 2007 12:52 PM
TaeKwon
Jan 24, 2007 07:20 AM
