AudiForums.com
-   Audi A6 (https://www.audiforums.com/forum/audi-a6-9/)
-   -   Low engine coolant temperature (https://www.audiforums.com/forum/audi-a6-9/low-engine-coolant-temperature-104791/)
SloRide Jun 11, 2008 12:42 PM
I have a 96 with the 2.8 and recently the engine coolant temp was reading low ( barely getting off the lowest reading). Several searches talked about the coolant temp sensor on the coolant pipe, back of the engine, passenger side. I located it and just for the sake of elimination I pulled off the connector sprayed on some contact cleaner on it and the sensor and BINGO! thegauge was back to reading the correct temperature. Lucky I guess but something to check before you go thru replacing the sensor.
