Lowering 2001 Audi
I would like to ask if someone can tell me what drop can i expect with these lowering springs? Any pictures would be great or something similar to imagine the view.
http://www.europerformance.co.uk/pag...roduct=3913365
or these
http://www.europerformance.co.uk/pag...roduct=3916847
or
http://www.europerformance.co.uk/pag...roduct=3876321
And which of these lowering springs would you recommend.
or these
or
About a 40mm drop on 19's
Another but on 18's I believe
The difference between 40mm and 50mm is not much so it's up to you...if you have a lot of speed bumps I would go with 40mm, may make your commutes a bit easier. Also from what I have read eibach's are the most comfortable ride for lowering springs (progressive rate springs like the cobra's you posted).
I have never seen Eibach's lowering springs that would lower 40mm. Just these http://www.europerformance.co.uk/pag...roduct=4020364
But these lower 30mm only. So the gap should be big enough.
I will choose 40mm lowering springs but what maker to choose? KONI or WEITEC because I have found springs that fit to my car on this website only unless you know more websites to buy lowering springs.
I don't know of any European distribution sites...I would get these
http://www.europerformance.co.uk/pag...sub_category=1
Car would stick well and sit low. They are also progressively wound so perhaps the ride quality would even be good.
caliherold
Mar 19, 2012 10:59 PM
