MAF sensor spudder problems
Old Sep 12, 2008 | 11:23 PM
michaelh305's Avatar
Anybody?
Old Sep 12, 2008 | 11:34 PM
auditech79's Avatar
The throttle body boot is the rubber Y hose right into the throttle body in front of your motor. With a vag com you can check to see if any un-metered air is entering the engine. Use a flash light and try to seperate the TBB hose and see if its cracked. They have been known to do that.
Old Sep 14, 2008 | 01:47 PM
Default MAF Spudder Update
I removed both diverter valves and the TBB. The TBB was blown up on the bottom. So I believe that's where the Vacuum leak is so I will order one today. Also the bigger hose coming off of the bottom of the passenger side Diverter valve looks dried so I will replace that also. Another question what sensor sits on top of the TBB? So I believe that my MAF was good the whole time I will keep you posted on the out come. Thanks
Old Sep 14, 2008 | 09:44 PM
auditech79's Avatar
The sensor on top of the TBB is a boost sensor for the ECM, it never really has any problems. A new TBB should take care of your problems.
Old Sep 15, 2008 | 12:16 AM
The reason I ask is because it seemed really oily in that boot will that hurt that sensor? And why would it be oily? Thanks
Old Sep 15, 2008 | 01:08 AM
auditech79's Avatar
No oil won't hurt the sensor, its normal to have a little oil in the intake system. If there is an excessive amount in the intake lines (like a quart!) then the PCV system is clogged up. You would need to change the valve attached to the back of the turbo Y pipe and all the hoses attached to it. The dealer sells it as a complete set. More than likely you're fine, i usually just take the valve off the Y pipe and spray some brake cleaner in there to clean off all the crusted oil in there.
Old May 11, 2013 | 03:57 AM
BryceHamernick's Avatar
Default Same issue
I am having this same issue, I have not checked the TBB but I will in a bit. I too bought a new MAF Sensor and have the same damn issue. It sounds like a lot of boost is coming out of the atmosphere so maybe I have the same issue.
Did anyone figure out the outcome of this issue?? Thank you
Boystaysin
Jan 6, 2014 09:01 AM
msd29
Oct 14, 2010 01:13 AM
bikejumpr2020
Jan 18, 2010 01:35 PM
SafewaySelect69
Sep 12, 2008 01:56 PM
michaelh305
Jul 29, 2008 06:37 PM
