Magnaflow mufflers?
Old Aug 8, 2008 | 09:43 AM
joetm's Avatar
i have the sport label remus catback with obx manifold and vast piggies ... sounds sleeper and im kinda upset but i cant justify spending another grand on a cat back ...
Old Aug 8, 2008 | 09:46 AM
joetm's Avatar
wow that youtube video sounded good ... what exactly would i need to do to get to that !!!
Old Aug 8, 2008 | 12:41 PM
oc_audica's Avatar
remus is pretty quiet...
did you get larger diameter piping on the exhaust?
Old Aug 8, 2008 | 02:14 PM
joetm's Avatar
unfortuanately the exhaust was one of the first things and most unresearched thing i bought for the car ... its stock diameter ... what diameter do you recommend i use and what material should the pipes be ill cut and hang my own right off my vast piggies i guess
Old Aug 12, 2008 | 02:55 PM
joetm's Avatar
bumpbump
Old Aug 13, 2008 | 03:33 PM
oc_audica's Avatar
2.5" should be good from the downpipes back
Old Aug 15, 2008 | 09:17 AM
jimwilly00's Avatar
Default I've got Magnaflow Mufflers and mini resonators on a Stage 3
with ASP downpipes (hollowed cats) and while I think the quality of sound is good, I'd like it a touch louder.
Here are a couple of youtubes of my car:
outside
http://www.youtube.com/watch?v=glQbeUO13Mw
inside
http://www.youtube.com/watch?v=VesUs...eature=related
Old Aug 15, 2008 | 02:34 PM
  #18
joetm's Avatar
ok what material should the pipes be like thickness im assuming stainless steel ?? im just going to use a bender and bend the stuff myself
how do i take the resonator out of the matgnaflow muffler
thanks
Old Aug 15, 2008 | 03:32 PM
  #19
jimwilly00's Avatar
Default No, what I meant was, I'm using mini mufflers as resonators
the part no's I have are 14445 and 14615. If you go to Magnaflow's website, you should be able to search for the part no and see a pic. I have 4" double walled slant cut tips as well (from Magnaflow).
the only part of the stock exhaust that was kept was the Y section right after the cat, why, I can't remember why. I think it was in case I ever decided to go back stock. The shop used 2.5in stainless tubing and used a basic compression bender. (not many curves in the exhaust to impede flow with the basic bends.
Old Aug 16, 2008 | 09:10 PM
  #20
joetm's Avatar
how thick is the stainless though??? -- 3mm --2mm???someone anyone ... ????????
