Moaning & Groaning from the front
Old May 20, 2008 | 08:52 PM
catdog's Avatar
Default Moaning & Groaning from the front
After I've driven awhile I start hearing and feeling a moan, groan, rumble from the front. I hear it when I'm going slow, if I turn the wheel stopped or not I hear the rumble and can feel it in the steering wheel. It started about a week ago and would usually stop after awhile. Now it seems to continue as long as I'm driving.
Car has 102,000 miles.
Service history:
Just did front brakes and the bearings felt ok.
93580 replaced steering pump, fluid level ok
81319upper & lower control arms
81319 right side drive axle
What next?
Old May 20, 2008 | 09:45 PM
paaudia6's Avatar
Member
Default RE: Moaning & Groaning from the front
hey my car does the samething..... 2003 a6 3.0 80k...... im thinkin maybe its the rack.... when its above 70 degrees out it does'nt do it at all kinda weird....
Old May 20, 2008 | 09:51 PM
catdog's Avatar
I hope it's not the rack. I just did the TB, water pump & tensioners. Glad I only paid 10500 for the car.
Old May 20, 2008 | 10:00 PM
paaudia6's Avatar
Member
thats what im doin next the timing belt...these cars are definitley fun to drive but little things go bad alot quicker then other types of cars....
Old May 21, 2008 | 01:12 PM
catdog's Avatar
Just drove the car for 45 min & it did not make the sound. It always does it in the afternoon when it's hotter.
What would the temperature have to do with the front end?
Old May 21, 2008 | 05:32 PM
paaudia6's Avatar
Member
my car does'nt make the sound when its warm out only when its colder say under 65 degress.... kinda weird....
Old May 21, 2008 | 05:34 PM
catdog's Avatar
It is weird, got to be something to this. Good for you summer's coming.
Old May 21, 2008 | 06:08 PM
LeAudi19's Avatar
i am sure it is something with the suspension have u tried pusshing the car from the fron tires slowly??? i did it and the car makes this anoying noise, and being here in chicago even going 5 mph, there are alot of bumbs and humbs and you can hear the ssound
Old May 22, 2008 | 12:12 AM
howif's Avatar
Had the same problem...it was related to the power steering. Specifically, there is a filter in the power steering system that gets dirty over time. This causes the pump to not get enough power steering fluid. Just have the dealer replace the filter.
Old May 22, 2008 | 12:31 AM
LeAudi19's Avatar
have you gotten you bold joints???? i think thats what theyr called, the thing behing the rim that connects to ur wheel and car
before i had them replaced they also caused a noise when i braked
i had those replaced when my brakes where worn out badly
