my new brakes are done
Old Apr 10, 2008 | 02:42 PM
votblindub's Avatar
Default my new brakes are done
Finished over the weekend. Zimmerman fronts, ATE rears and Pagird RS4-2-1 pads all around.
new rear ATE rotors
new rear ATE rotors
new front Zimmerman rotors
new front zimmermans
pagid rear pad
pad surfaces. new is on top
pad surfaces. new is on the right
rear pads. new ones on the left
rear rotors. old on the left
rear rotor and caliper
new brake rotor in palce
front rotor hat painted
new front rotor painted
inside of new front rotor
Old Apr 10, 2008 | 03:09 PM
weed4life's Avatar
Default RE: my new brakes are done
N I C E ! You shoulda maybe painted the calipers while you were doing the brakes. Did you get SS lines as well? Hows the braking feel? Diamater on the new rotors look larger giving pads more surface to grip.
Old Apr 19, 2008 | 07:01 AM
Cmoney's Avatar
I did my brakes on a 2000 2.7. I painted my calipers black. It gave them a nice look.
Old Apr 19, 2008 | 10:49 AM
Slurm's Avatar
why cross drilled in the front and not the back?
Old Apr 20, 2008 | 11:56 AM
votblindub's Avatar
ORIGINAL: weed4life
i plan to powdercoat the calipers flat red, actually. everyone has the high gloss, i want flat red
Old Apr 20, 2008 | 11:57 AM
votblindub's Avatar
ORIGINAL: Slurm
dont really need drilled ones outback. i just did it as maintenance.
i dont need SS lines because i dont do much city driving, no auto rossing and this car isnt seeing track time, so why invest 150 dollars into something i wont actually NEED, ya know? once i need lines, ill get stainless, but for now, OEM is enough
Old Apr 20, 2008 | 12:17 PM
katcoota's Avatar
ORIGINAL: Slurm
The majority of the car's braking is done with the front rotors (unless you drive backwards all the time). Hence they are almost always a larger diameter, and wear out quicker.
For day to day driving, upgrading the rear rotors to cross drilled is almost cosmetic as the effects of slightly cooler brakes will be negligable.
Slotted, cross drilled and SS lines are great if you are taking itto the track. Then you will certainly benefit from every little tweak you can get to enhance your car.
Old Apr 20, 2008 | 09:25 PM
votblindub's Avatar
ORIGINAL: katcoota
ORIGINAL: Slurm
a-yup! exactly. i dont plan to get things i dont really need on the car. i might get sway bars or something like that, to reduce body roll. im not building a track rat.
Old Apr 21, 2008 | 01:15 PM
euro_2nr's Avatar
+1... dats why I haven't upgraded my brakes at all! But as soon as I need to I'll probly do something similar.
Old Apr 21, 2008 | 04:07 PM
Wayne.L's Avatar
which bbs rim is your's???? look really hot with the drilled rotor!
