Navigation Problem
Old Jun 15, 2012 | 01:47 AM
edmundk3's Avatar
Default Navigation Problem
I recently wrapped my roof on my new A6 & had to loosen the antenna a bid to get the wrap under it.
Now my navigation shows that I'm in the middle of the Pacific Ocean....
I'm concerned that I might have over tighten the antenna to avoid water leaking in.....
Any suggestions would be greatly appreciated.
Thanks
Old Jun 15, 2012 | 12:16 PM
eazy211187's Avatar
Have you try re-adjusting the position on the screen? Because loosening antenna affect the Nav. Have you reset the Nav?
Old Jun 16, 2012 | 12:56 AM
edmundk3's Avatar
I don't know how to re-position on the screen.... but I have reset the MMI & the Navigation several times. I'm thinking that the guys who re-upholstered my interior might have forgotten to re-connect something....
Thank you so much for your time.
Old Jun 16, 2012 | 11:59 AM
eazy211187's Avatar
If you have the rear window shade, there's a panel on the back ceiling that you pull down. Behind there is the brake light bar and the connection to the roof antenna. But when removing the panel don't pull it from the window side, remove it from the inside closes to the dome light(there are 4 pin then out pull down towards the rear window).
Hope that helps.
Iron KIM
Jul 6, 2014 07:58 PM
lukacio
Jan 20, 2011 04:54 PM
instruct9r
Jan 12, 2011 11:24 AM
jhon
Sep 11, 2006 11:42 PM
brightmosquito
Oct 27, 2005 09:35 PM
