Need Expert to Interpret Scan for Me
1999 A6 2.8 FWD
The INSP light had been on for a while - I ignored it for a thousand miles or so. I was doing some work on it and had the battery cable off for a couple days ( I was replacing the stalk switches on the column). When I reconnected the battery, it started up rough and only would idle at 250 rpm or so. I hear in a previous post it could be throttle body related, and I tried the hold down the gas/key on thing. It did not help. Anyway, I was able to get someone (who is gone now) to pull a scan for me, but I do not know how to interpret it. Any experts out there that might be able to help. Thanks... ...Mike VCDS Windows Based VAG/VAS Emulator VCDS Version: Release 908.1 Data version: 20091018 w w w . R o s s - T e c h . c o m Dealer/Shop Name: Workshop Code: 000 00000 Self-Diagnosis Log Saturday,20,February,2010,14:45:19:24960 VIN: WAUAA24B8XN999999 License Plate: Mileage: 208850km-129773mi Repair Order: Chassis Type: 4B - Audi A6 C5 Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75 ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AHA.lbl ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.lbl ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl ------------------------------------------------------------------------------- 76 77 Mileage: 208850km/129773miles Part No: 4D0 907 551 AH Component: 2.8L V6/5V MOTR AT D04 Coding: 06152 Shop #: WSC 40536 3 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17967 - Throttle Body (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent 17953 - Throttle Valve Controller: Malfunction P1545 - 35-00 - - Readiness: 0110 1101 Part No: 4B0 927 156 F Component: AG5 01V 2.8l5V USA 8509 Coding: 00000 Shop #: WSC 00000 1 Fault Found: 00526 - Brake Light Switch-F 27-00 - Implausible Signal Part No: 8E0 614 111 C Component: ABS/ASR 5.3 FRONT D00 Coding: 00003 Shop #: WSC 02325 No fault code found.VCDS Self-Diagnosis Log Saturday,20,February,2010,14:45:20:24960 Page 2 VIN: WAUAA24B8XN999999 License Plate: Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI8.lbl ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-919-xxx-17.lbl ------------------------------------------------------------------------------- Part No: 4B0 820 043 P Component: A6-Klimavollautomat D62 Coding: 00160 Shop #: WSC 02325 No fault code found. Part No: 4B0 959 655 H Component: Airbag Front+Seite 0002 Coding: 00106 Shop #: WSC 02324 No fault code found. Part No: 4B0 919 930 RX Component: C5-KOMBIINSTR. VDO D18 Coding: 07262 Shop #: WSC 19411 No fault code found. VCDS Self-Diagnosis Log Saturday,20,February,2010,14:45:20:24960 Page 3 VIN: WAUAA24B8XN999999 License Plate: Address 35: Centr. Locks Labels: 4B0-962-258.lbl 09-10 - Adaptation Limit Surpassed - Intermittent 09-10 - Adaptation Limit Surpassed - Intermittent ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Part No: 4B0 962 258 J Component: Central Lock/Alarm D32 Coding: 15885 Shop #: WSC 00000 17 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch; Passenger Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01558 - Contact Switch in Locking Cyl; Driver Side; Close (F241) 29-00 - Short to Ground 01557 - Contact Switch in Locking Cyl; Driver Side; Open (F241) 29-00 - Short to Ground 01389 - Tailgate Open Switch (F124) 29-00 - Short to Ground 01563 - Interior Lock Switch; Driver Side (E150); Lock 29-00 - Short to Ground 01564 - Interior Lock Switch; Driver Side (E151); Unlock 29-00 - Short to Ground 00947 - Trunk Lid remote Control Switch (E188) 29-10 - Short to Ground - Intermittent 01565 - Luggage Compartment Light (W3) 29-10 - Short to Ground - Intermittent 00955 - Key 1 00956 - Key 2 01574 - Alarm triggered by Door Contact Switch; Right Rear 35-00 - - 01573 - Alarm triggered by Door Contact Switch; Left Rear 35-00 - - Address 36: Seat Mem. Drvr Labels: None Part No: 4B0 959 760 A Component: Sitzmemory D05 No fault code found. VCDS Self-Diagnosis Log Saturday,20,February,2010,14:45:20:24960 Page 4 VIN: WAUAA24B8XN999999 License Plate: Address 45: Inter. Monitor Labels: 4B0-951-173.lbl ------------------------------------------------------------------------------- End --------------------------------------------------------------------- Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 02325 No fault code found. Address 56: Radio Labels: None Part No: 8N0 035 186 A Component: Radio D03 Coding: 00207 Shop #: WSC 40536 No fault code found. |
Go to www.ross-tech.com and www.BentleyPublishers.com
My Bentley does not cover the 1999 model year. |
To be honest with you 90% of these codes are caused by having the battery disconnected. I would imagine that if you erased all the codes the only ones that would return is the throttle body code and brake switch code. The brake switch code is important for cruise control, braking, ABS reasons etc. but it won't cause the engine to idle weird. That will lie with the throttle body. To do a throttle body alignment without a vag com scanner just turn the key to the ON position and leave the car alone for 12-15 minutes, the throttle body should set itself. I would recommend cleaning the throttle body valve with brake cleaner before doing the aligment though.
Not knowing much about the scans, the
3 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low -P1602 - 35-10 - - - Intermittent 17967 - Throttle Body (J338): Fault in basic settings-P1559 - 35-10 - - - Intermittent 17953 - Throttle Valve Controller: Malfunction-P1545 - 35-00 - - would seem to indicate that its TB related, I have tried a few of the key/timing ( 2 minutes, 15 minutes, etc) tricks now, and none of them even make any noise at the TB. Are the gimmicky resets 'official' ? If they do not work, should I even hope that a VAG-COM based TBA would be better ? ( If so, I'll look out on vag tool finder dot com and see if I can rustle up a unit near Cary. NC. Thanks... |
Correct, the voltage too low fault is from the battery, the throttle body will usually throw those codes when the battery is removed. If the key cycle trick isn't working for you, it needs to be done with a vag com. You could also have the dealer re-set it for you but that could be pricey.
Did you disconnect the battery first, reconnect and do the throttle body alignment using the procedure? You should.
throttle body calibration guaranteed............... adaptation channel 61 in the ECM if i'm not mistaken
I will have access to a vag-com tomorrow.
I am unfamiliar with its use, but found a procedure at www dot ross-tech dot com /vag-com/cars/throttlebody.html One of the pre-reqs says there should be * No DTC's in the Engine Controller I am very new at this (but want to learn) Do the codes listed here mean I can't do this? Address 01: Engine Labels: 078-907-551-AHA.lbl Part No: 4D0 907 551 AH Component: 2.8L V6/5V MOTR AT D04 Coding: 06152 Shop #: WSC 40536 3 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17967 - Throttle Body (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent 17953 - Throttle Valve Controller: Malfunction P1545 - 35-00 - - Readiness: 0110 1101 Also - I'm supposing I have motorized throttle control and not drive by wire - is that right ? Its a 99 A6 (C5) AHA 2.8 30v Thanks again - I will let you all know how it works out. ...Mike |
| All times are GMT -4. The time now is 04:12 AM. |
