Need help
Old Aug 18, 2011 | 10:22 PM
Sc0tt's Avatar
Default Need help
Guys I've got a problem with a sign light. There is usually cruising range what shows you how many miles you can drive on the gasoline you have. I don't know what is that. Does somebody know what is it? -->
Old Aug 18, 2011 | 11:53 PM
bigdadi's Avatar
headlight leveling system ... warning
The motor which controls the height may had failed and the drivers headlamp had dropped to the lowest setting.
There is also Front Head Light Range Self Level Sensor to check out, it is right by the struct
Old Aug 19, 2011 | 10:43 AM
Sc0tt's Avatar
Thanks a lot! How can I fix it on my own?
Old Aug 19, 2011 | 02:09 PM
ppgoal's Avatar
I went through this last year. Front sensor is integrated and requires replacement of the left headlight. Unsure about rear sensor. Since I did not notice my lights moving or out of alignment, I removed fuse #10 and the icon went away. Do a search, because I posted this before but I am not 100% sure I remember the fuse number.
Old Aug 21, 2011 | 09:10 AM
bob martin's Avatar
Fuse 10.
Bob
