Need your help guys.
I have a 05 a6 quattro 3.2 that I initially thought the battery was drained because I left the headlights on auto. Car cranks and starts up on first try but dies immediately. After that if I keep trying just cranks.
Come back an hour later same thing. Starts up and shuts off immediately. I checked the 20a fuse on passenger side and it's good. I'm not sure where the fuel pump relay is? Any help is greatly appreciated. Thanks |
Monday,31,July,2017,18:11:54:60261
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.1.3.0 (x64) Data version: 20170320 DS267.7 www.Ross-Tech.com VIN: WAUDG74F65N108053 License Plate: JENSSY Mileage: 257590km-160059mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F (4F0) Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56 61 62 72 77 VIN: WAUDG74F65N108053 Mileage: 257590km-160059miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Cannot be reached 1100 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Cannot be reached 1100 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 4F1 910 559 B HW: 4F1 907 559 A Component: 3.2l V6 FSI 0050 Revision: --H15--- Serial number: Coding: 01050106190F0120 Shop #: WSC 02325 785 00200 VCID: 2A5BD34D85144C1197-807E 2 Faults Found: 18082 - Powertrain Data Bus P1674 - 008 - Implausible Message from Instrument Cluster Freeze Frame: Fault Status: 01011000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 40 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 17:08:51 Freeze Frame: RPM: 0 /min Mass Air / Rev.: 0.0 mg/str Temperature: 33.0�C Engine Off Voltage: 11.73 V Speed: 0.0 km/h 18347 - Powertrain Databus P1939 - 009 - Missing Message from Controller for Access & Start Auth. Freeze Frame: Fault Status: 01011000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 40 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 17:08:51 Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 H HW: 09L 927 156 Component: AG6 09L 3.2 FSI USA 0020 Revision: --H01--- Serial number: 0050235 Coding: 0001002 Shop #: WSC 02335 785 00200 VCID: 29592C41801247099E-807C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H03 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020895 Shop #: WSC 02331 785 00200 VCID: 2D51D851B4FA5B2972-8078 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 198 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 17:03:57 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4082 Hex Value: 0x0025 Hex Value: 0x018B Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Cannot be reached ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb Part No SW: 4F0 910 730 E HW: 4E0 035 729 Component: Interfacebox H43 1070 Revision: 00000000 Serial number: 360CH057521274 Coding: 0000003 Shop #: WSC 12345 111 45725 VCID: 23453E69E23E9D59D4-8076 Subsystem 1 - Part No: 4F0 910 609 B Component: Bedienteil MMIC6H07 0010 Subsystem 2 - Serial number: 00000000118468 Subsystem 3 - Serial number: 0102.03.050000000100010313� Subsystem 4 - Serial number: 010313� 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 198 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:26:09 Freeze Frame: Bin. Bits: 10 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.clb Part No SW: 4F0 910 043 HW: 4F1 820 043 J Component: KLIMABETAETIGUNGH11 0150 Revision: 00000026 Serial number: 00000000123049 Coding: 0524326 Shop #: WSC 02331 785 00200 VCID: 5BB546899ACEE599DC-800E 2 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:16:07 Freeze Frame: Bin. Bits: 00001000 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:16:07 Freeze Frame: Bin. Bits: 00001000 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 HW: 4F0 907 279 Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0013123 Shop #: WSC 02335 785 00200 VCID: 66C3677D518CA87173-8032 Subsystem 1 - Component: Fehler Lin-Slave 01 Subsystem 2 - Component: Fehler Lin-Slave 02 1 Fault Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 31 Reset counter: 158 Mileage: 257596 km Time Indication: 0 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 Revision: 00000000 Serial number: AUZ5ZBE7129818 Shop #: WSC 00000 000 00000 VCID: 1B350689DA4EA5991C-804E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.clb Part No SW: 4F0 910 655 B HW: 4F0 959 655 A Component: 56 AIRBAG AUDI8RH29 0310 Revision: 10H29000 Serial number: 00359D089ZZV Coding: 0013622 Shop #: WSC 08315 444 55870 VCID: 2643277D910C6871B3-8072 Subsystem 1 - Part No: 4F0 910 339 Component: BF-Gewichtsens. 002 0040 Subsystem 2 - Serial number: 6332CSME08324E6A8 Subsystem 3 - Serial number: 6342CSME09091473 Subsystem 4 - Serial number: 6351HSME065F0E4EP Subsystem 5 - Serial number: 6361HSME06530071X Subsystem 6 - Serial number: 6371VSME064A597C- Subsystem 7 - Serial number: 6381VSME064B4C23Q 1 Fault Found: 02095 - Component Protection Active 000 - - ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenks�ulenmodul H07 0230 Revision: 00H07000 Serial number: 90025050570161 Coding: 0002021 Shop #: WSC 02323 785 00200 VCID: 66C3677D518CA87173-8032 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H06 0080 1 Fault Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:16:05 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 950 M Component: KOMBIINSTR. M73 H10 0610 Revision: 00500000 Serial number: 4R870Z235 Coding: 0067263 Shop #: WSC 12345 111 45725 VCID: 1E330F9DC95CB0B1FB-804A 2 Faults Found: 00771 - Fuel Level Sensor (G) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 198 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:29:29 00438 - Fuel Supply Sensor 2 (G169) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 198 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:29:29 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.clb Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H10 0060 Revision: 10 Serial number: 1200805221024C Coding: 6CFE73C41B3104 Shop #: WSC 02054 002 1048576 VCID: 275D2A799606717988-8072 2 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:16:06 00474 - Control Module for Immobilizer 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:16:06 ------------------------------------------------------------------------------- Address 37: Navigation Labels: None VCID: 55A150B1BCEA33E9EA-FFFE ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Cannot be reached ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 E HW: 4F0 907 289 E Component: Komfortgeraet H15 0100 Revision: 01000015 Serial number: 01003013850000 Coding: 0423997 Shop #: WSC 12345 111 45725 VCID: 2C57D5558FE0522165-8078 Subsystem 1 - Part No: 1K0 951 605 A Component: LIN BACKUP HORN H02 1301 10 Faults Found: 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 146704 km Time Indication: 0 Date: 2010.07.17 Time: 13:56:45 01519 - Bulb for Back-Up Lights; Right (M17) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 257484 km Time Indication: 0 Date: 2017.07.18 Time: 11:10:48 02198 - Bulb for Tail Light 2; Left (M49) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 257484 km Time Indication: 0 Date: 2017.07.18 Time: 11:10:48 02735 - Bulb for Tail Light 3; Right 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 253601 km Time Indication: 0 Date: 2005.01.12 Time: 02:17:55 01134 - Alarm Horn (H12) 014 - Defective Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 253601 km Time Indication: 0 Date: 2005.01.12 Time: 02:17:55 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 254 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 10:23:17 01506 - Bulb for Rear Fog; Right (L47) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 254 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 10:23:17 02734 - Bulb for Tail Light 3; Left 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 256266 km Time Indication: 0 Date: 2017.01.13 Time: 12:25:06 01518 - Bulb for Back-Up Lights; Left (M16) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 256266 km Time Indication: 0 Date: 2017.01.13 Time: 12:25:06 01502 - Bulb for Rear Fog; Left (L46) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 158 Mileage: 256442 km Time Indication: 0 Date: 2017.01.24 Time: 13:28:03 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000073104 Coding: 0001114 Shop #: WSC 02323 785 00200 VCID: 5EB34F9D89DCF0B1BB-800A 1 Fault Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 8 Reset counter: 158 Mileage: 257596 km Time Indication: 0 Date: 2063.15.31 Time: 16:00:00 Freeze Frame: Voltage: 11.500 V Temperature: 43.0�C ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Cannot be reached ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0005022 Shop #: WSC 02334 785 00200 VCID: 5DB1489184DAEBA9A2-8008 2 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 4 Fault Frequency: 54 Reset counter: 158 Mileage: 257592 km Time Indication: 0 Date: 2017.07.31 Time: 04:40:40 Freeze Frame: Voltage: 10.97 V Count: 247 00576 - Terminal 15 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 4 Fault Frequency: 60 Reset counter: 158 Mileage: 257592 km Time Indication: 0 Date: 2017.07.31 Time: 04:40:40 Freeze Frame: Voltage: 10.97 V Count: 41 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 C HW: 4F0 907 357 C Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000016 Shop #: WSC 02331 785 00200 VCID: 2643277D910C6871B3-8072 Subsystem 1 - Part No: 4F0 941 329 A Component: AFS-Modul links H05 0010 Subsystem 2 - Part No: 4F0 941 329 A Component: AFS-Modul rechtsH05 0010 1 Fault Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 17 Reset counter: 158 Mileage: 257592 km Time Indication: 0 Date: 2017.07.31 Time: 16:17:41 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H12 0490 Revision: 00000000 Serial number: 00000000029763 Shop #: WSC 30592 001 1048576 VCID: 23453E69E23E9D59D4-8076 Subsystem 1 - Part No: 4F0 915 105 C Component: von VA0 1234567890 Coding: 344630393135313035432056413031323334353637383930 Shop #: WSC 30592 001 1048576 5 Faults Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:17:41 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 158 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:17:41 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 4 Reset counter: 255 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:29:43 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 4 Reset counter: 255 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 16:29:43 02277 - Quiescent Current Stage 6 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 257597 km Time Indication: 0 Date: 2017.07.31 Time: 17:10:28 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Cannot be reached ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End-------------------------(Elapsed Time: 04:19)-------------------------- |
