New Thermostat?
New Thermostat?
Hey I'm new.
My '97 A6 doesn't heat up enough to put the needle in the middle of the water temp gauge, although I do still get hot air out of my vents.
Does this indicate that I need a new thermostat?
Also, is there anything else I should do while I am replacing the thermostat. (For example on my m3, while I am in there I replace the plastic thermostat housing with an aluminum one, replace the water pump, and get rid of the useless secondary cooling fan.)
Thanks for your help.
