Noisy Power Steering
Old Dec 26, 2007 | 10:59 PM
tonyk's Avatar
Default Noisy Power Steering
I live in Chicago and I've got a '02 A6 w/ a 3.0. The other night, it was pretty cold...around 10 F. The car worked well, but my power steering was very noisy...like it was low on fluid. I knew it was full..anyway, it stopped making noise when the car warmed up. Anyone ever had this happen? The steering worked great, it was just noisy! Looking for input!
Thanks!
Old Dec 26, 2007 | 11:07 PM
auditech79's Avatar
Default RE: Noisy Power Steering
Its ok un-less its leaking. You can try and aerate the fluid by taking off the resivior cap and turning the wheel back and forth (lock to lock) several times to get all the air bubbles out.
Old Dec 27, 2007 | 12:36 AM
dropscience's Avatar
Whenever I turn the wheel to the limit I hear a ringing sound, I think the problem is related to the power steering fluid
Old Dec 27, 2007 | 12:40 AM
auditech79's Avatar
ORIGINAL: dropscience
It almost always is a problem with the fluid, but its either a matter of it leaking or you just not topping it off regularly because mineral oil evaporates.
Old Dec 28, 2007 | 12:28 AM
tonyk's Avatar
Should I change fluid? Just suction it out? Suggestions?
Old Dec 28, 2007 | 11:26 AM
catdog's Avatar
Mine started like yours and ended with a pump replacement. May be the pump since it stopped after the car warmed up. May be nothing to worry about now. If it continues or gets worse, I would start with a flush. Use Pentosin or Febi. It's about $20 a quart on line. Your dealer may be easist if the price is about the same. You can suction it out adding fresh fluid until until it's clean. There's better ways to flush but I didn't want to take a chance of running the engine without fluid. Best to areate with the front wheels off the ground. Check for leaks. The first flush bought me about 2 months before it started again. Maybe you'll get lucky.
Our engine was only made for a couple of years and I couldn't find a rebuild any where and needed one fast, dealer $411.
Old Dec 28, 2007 | 11:36 AM
hxgaser's Avatar
I just saw this for power steering flush. It is for an A8 but there is a revision/clarification for A6 at the bottom.
http://www.audipages.com/Tech_Articl...r/psflush.html
keithymason2471
Mar 30, 2015 04:33 PM
Wac786
Aug 3, 2011 12:47 AM
Lastb0isct
Feb 17, 2009 03:15 PM
