O2 sensor codes
Old Apr 25, 2009 | 11:39 AM
itledo's Avatar
Default O2 sensor codes
2000 A-6 2.8l
The CEL light is on and Im getting codes 17530(P1122), 17548(P1140) and 16544(P0160)
When I check with an ohm meter as per Audiworld tech article which tells you to check resistance at connector in engine compartment, I get a reading below 20 ohms which the article states is OK. The car they are testing in the article is a B5 A4, does that matter? Thanks......
Old Apr 25, 2009 | 11:46 PM
auditech79's Avatar
P1122
O2 Sensor Heater Circ.,Bank2-Sensor2 Open
17548
P1140
Bank2-Sensor2 Internal Resistance too High
16544
P0160
O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected
Replace the O2 sensor on the drivers side, behind the cat conveter. The O2 sensor is toast. Those OHM tests only work on specific O2 sensors.
Old Apr 26, 2009 | 05:13 AM
itledo's Avatar
Default O2 sensor
Thanks.......
teddysart
Jul 4, 2012 12:52 PM
Jpadguy
May 15, 2012 05:01 PM
Jpadguy
May 12, 2012 08:14 AM
Chingon1988
Jan 7, 2012 12:46 AM
hartsoe1
Apr 4, 2008 06:39 AM
