Oil change on 04 A6 1.9 tdi auto
Hi all,
I'm sorry if this has been posted a hundred times already but I found nothing in a search. What is the procedure for getting the undertray off and where is the engine oil drain plug. Cheers Ian:confused: |
It's held on with a bunch of silver screws the heads are about 19mm diameter give them about 1 turn and they come right out. There are also some 10mm screws in front of the wheel wells. Once it's off you will see the drain plug.
Thanks Jackmup, but I undid all the screws and bolts i could find and it still would not
come out. I managed to get the rear half off which I presume reveals the gearbox but could not get the front half out..... it still appeared to be attached to the wheel arch liners in some way. Cheers Ian |
I'm sure you already checked for extra srews so try giving it a yank. It may just be a little plastic push pin holding you up. Either it will come loose or you'll find where it's hanging up.
Okee dokee.... I'll give it a try.
Thanks for the input Jackmup. Cheers Ian:) |
