oil temp sensor
Old Nov 4, 2008 | 08:39 PM
bmr18t's Avatar
Default oil temp sensor
my oil temp sensor has not worked ever since i bought the car. does anyone else have this problem? as anyone fixed it? and where is the sensor?
Old Nov 4, 2008 | 08:40 PM
bmr18t's Avatar
i have a 2000 a6 2.7
Old Nov 5, 2008 | 12:12 PM
RedShoeRider's Avatar
Yup, had the same problem. Oil temp sits at zero forever and ever.
On my 01 2.7t, the sensor is on the bottom of the oil pan. If you're laying under the car, it sits into a recess in the bottom of the pan. It's the only thing there besides the nice, shiny aluminum. I think it's 3 or 4 bolts and a gasket that holds it in place (it's been a while since I did mine). Take the bolts off and with a little wiggling it'll come out. New gasket, new sensor, make sure you clean the seating surface of the gasket well or else you'll be chasing leaks forever. I have no idea what the torque specs on the bolts are; just be careful, as the pan is aluminum.
Oh, and drain your oil first. If not, it's going to drain all over you when you pull the sensor out!
-Red
Old Nov 26, 2008 | 05:21 PM
bmr18t's Avatar
okay so i called audi and they don't have a oil temp sensor. they do for 99 and older but not newer. is the oli temp and oil level sensor the same sensor?
Old Nov 26, 2008 | 06:51 PM
A62TURBO's Avatar
-Red
Isn't that the oil level sensor?
Old Nov 28, 2008 | 10:52 PM
bmr18t's Avatar
thats where my problem is? where is the oil TEMP sensor?
Old Dec 4, 2008 | 03:13 PM
I think it serves double-duty as the temperature sensor and level sensor on the A6's after 2000. When mine ate itself a few winters ago (while the car was still under warrentee), that's what they replaced in the shop.
-Red
Old Dec 4, 2008 | 11:08 PM
james0013's Avatar
This may sound like a really silly question but how do you know the oil sensor is not working?
I ask because I can not remember when I have seen my oil temperature gauge move but it does not register below 150 deg F (65-66 deg C). However it has been a while since I took the car on a run longer than my 7 mile 20 minute commute. However this is long enough for the temperature gauge to get up to the operating temp.
I am taking to car on a long trip to Virginia this weekend so I guess that will give me a chance to see if the oil temperature rises.
I guess the other question is how long in terms of time and distance does it take for the oil to get to a temperature that will register on the gauge.
Thanks
James
Old Dec 4, 2008 | 11:09 PM
james0013's Avatar
Sorry for some reason, this post appeared twice
RedA4guy
Aug 7, 2014 08:41 AM
toboater
Oct 26, 2010 12:15 PM
carhopper
Aug 23, 2007 07:21 AM
