p1411 and p1411 need som advice
Old Dec 27, 2008 | 12:56 PM
millenia's Avatar
Default p1411 and p1411 need som advice
got 2000 a6 2.7 with p1411 and p1423 codes on it, scanned it and looks like its a evap system thing, dealer replaced the air pump codes keep comming back, wondering if i can fix it alone?
Old Dec 27, 2008 | 06:06 PM
NH_USA's Avatar
P1411 and p1423 are secondary air injection codes... If the air pump has been repalced it is either a vacuum line, a valve, or a plugged air line to the manufold. Since both sides are showing codes it probably not one of the valves.
I would guess that 75% of the problems with Sec Inj codes are vacuum lines
Old Dec 27, 2008 | 08:48 PM
millenia's Avatar
Thanks, how do I find vaccum lines, do you like a picture of the engine showing where the vaccum lines are??? i m lost with this thing
Old Dec 29, 2008 | 12:45 PM
NH_USA's Avatar
The pump is low on the left front of the vehicle with a large (1" os so) plastic feed line going to the front upper center of the motor. It feeds two black valves. connected to the valves are small vacuum lines.
PS - Get a Bently manual -- It tells all --OK almost all ---OK it tells most of the impotant stuff..
kbunting
Sep 5, 2010 04:19 PM
bdmstang
Dec 10, 2009 04:40 PM
mikehh
Jan 25, 2009 01:30 PM
mikehh
Jan 25, 2009 01:24 PM
bolob5
Jul 10, 2008 01:03 PM
