Plastic motor pan and filter question
Old Dec 25, 2006 | 08:40 PM
jeffgrice's Avatar
Default Plastic motor pan and filter question
Hi,
The 2005 A6 I bought has damage to the black plastic pan under the motor....scrapes and a hole (a mechanic, not,cut an access hole to the oil drain).
What is the purpose of this pan and will there be any issues if I just remove it?
Also, where is the oil filter on this car....someone had said it it on the top side of the motor - I don't see it.
Thanks and happy holidays.
Jeff
Old Dec 27, 2006 | 03:51 PM
SouthboroAudiGuy's Avatar
Default RE: Plastic motor pan and filter question
Leave the pan on -- it aids in aerodynamics and cooling air flow. Don't worry if the hole cut out is small and especially don't worry about scrapes.
Oil filter is on the bottom. You'll need to remove the belly pan to get to it.
Old Dec 29, 2006 | 03:37 AM
dankhound's Avatar
What engine? If its a 3.2 it will be on the top under a plastic cover at the rear of the engine. The cover just clips in and pulls off. No secruring hardware. It is a canister type filter. The canister is black and has a large hex portion for a socket. I think its a 36mm. Maybe a 34.
Old Dec 29, 2006 | 06:36 PM
AudiTech04's Avatar
Also since the angle of the housing is completly retarded, make sure you put some rags underneath it
Old Dec 29, 2006 | 06:56 PM
techbod's Avatar
remove the plastic under shield
[IMG]local://upfiles/12092/16B6EF8D34504DD9A2D335D5E658AF4D.jpg[/IMG]
Old Dec 30, 2006 | 12:22 AM
dankhound's Avatar
Agreed. Those enginners need to stop making daily trips to amsterdam and get their act together.
Old Dec 31, 2006 | 06:20 PM
AudiTech04's Avatar
ORIGINAL: avant80@2.6
Yeah, that picture isnt for an 05 A6
Old Jan 1, 2007 | 02:42 PM
dankhound's Avatar
Is that picture supposed to be a 1.8 or do they put the filter for the disels on the bottom instead of the top?
StaviLasagna
Apr 18, 2012 11:05 PM
qwert
Dec 1, 2006 10:03 PM
kraylon
11
Oct 19, 2006 03:39 AM
viper771
Mar 7, 2006 05:52 AM
cdc28685394
Jan 15, 2006 08:12 PM
