plese help i need new cats!!!
Its time to change my cats on my 1999 2.8 and i just wanted to ask if anyone has use UNIVERSAL cats to replace the stock ones? Did they work? Did your check engine light came off? and who did you get them from?
Thanks for the help!!! |
RE: plese help i need new cats!!!
New Cats??? Try the local animal shelter. I hear that they always have a few to give away. If you get the black ones you'll be ready fro Halloween.
Or you could try Chris Semple at Force Five in Concord NH 603-223-6700. I would stay away from universal cats. As for the CEL - It depends upon the reason the cel is on. If it is an O2 sensor and you change the cats then the cel will come back onafter you clear the codes. |
ORIGINAL: NH_USA New Cats??? Try the local animal shelter. I hear that they always have a few to give away. If you get the black ones you'll be ready fro Halloween. Or you could try Chris Semple at Force Five in Concord NH 603-223-6700. I would stay away from universal cats. As for the CEL - It depends upon the reason the cel is on. If it is an O2 sensor and you change the cats then the cel will come back onafter you clear the codes. I would try the universal cats if they are available... especially if your only drivingthedarned car, and not modding it. find yourself a muffler shop... those shady bastards can putsomething together.Trust me... there's a few in Chicago that work miracles... |
GO ahead and spend your money on a universal cat and but remember you were warned that they often give trouble on an Audi.
k how about the aftermarket direct fit option would that be better
OK as long as they are OEM or better
how about straight pipes no cats lol
Only if you have tobacco to put in them!
i'm running universal magnaflow cats with no problem, maybe had 1 cel in 2+ years..
however i did replace one afterward, and pretty much need to replace it again but that could be related to my bad o2 sensors that i replaced recently |
yes i would link those problems together
