Possessed right blinker - (FIXED)
So I decided to do the clear corner mod in my car, everything went great until I put everything back together, now for some reason the front blinker in the passenger side won't work and the side and back blinkers "blink" way to fast, the drivers side is all right, front, middle and back "blink" at the right pace. I checked the front passenger side blinker bulb and it's not burned out. I first though it was the hazard relay switch, but I changed it and I still have the same problem, I will check fuse #2 to see if it's burned but if that was the case then none of the blinkers would work, right? Can you think of something else I should be checking? Thank you very much in advance.
RE: Possessed right blinker - Not hazzard switch
Thanks for the replay oc_audica, now do you mean wher you put the bulb itself you know the part that has the 3 little prongs that hook up to the headlight aseembly? Or do you mean the main hook up that also has the low and high beam?
iirc you can pull out entirely the part that holds the turn signal bulb. on the side of this piece there should be a metal conductor that touches another conductor once you put the light back in and turn the piece in place. i wish i could be more descriptive but i'm trying to recall this from my bad memory[:'(]
thank you very much oc_audica, it was one of the connectors on the blinkey contact point on the headligh, apparently I moved it out of place when doing the clear corners, now it was too low to contact the little prong from the blinker assembly, I went ahead and connected it directly to the blinker assembly prong and now everything works great, even the left right side is blinking at normal pace.
01AudiA4
04-17-2008 02:24 AM
