Power steering fluid leak - repair
Old Mar 27, 2012 | 02:04 PM
copper07's Avatar
Default Power steering fluid leak - repair
1998 A6 Quattro 30v
In the process of changing my radiator I have noticed that the power steering fluid is leaking out of the 2 connections of the cooler on the front of the car. I think I maybe able to disconnect the hoses cut off about .5 inch and reattach the hoses to the cooler. Has anyone had this same issue? Also do I need to to anything special when disconnecting the hoses on the power steering fluid cooler?
Thanks
Old Mar 27, 2012 | 02:47 PM
madridlover's Avatar
Originally Posted by copper07
1998 A6 Quattro 30v
Thanks
If you still have the OEM clamps on the hoses that's probably the culprit. I cut one hose back a little and the other I didn't. Just replace the clamps with the American screw clamps and you'll be golden.
Old Mar 27, 2012 | 05:01 PM
copper07's Avatar
Cool. That's what I will do. Thanks!
Old Apr 7, 2012 | 08:47 PM
copper07's Avatar
I put one of the screw down clamps on the on end that looked like it had a small leak. Then I topped off the fluid. Thanks for your help.
Old Apr 7, 2012 | 10:03 PM
bigdadi's Avatar
Change those OEM hose clamps to the screw ones if they can turn by your screwdriver pushing. This means oem clamps are losing its strength.
vtraudt
Feb 25, 2012 11:09 AM
2000A4_KS
Nov 15, 2010 12:44 PM
Chris BLK Audi
Mar 4, 2010 05:24 PM
bwilcox100
Dec 6, 2008 04:09 PM
boy412
Jan 26, 2008 06:59 PM
