Problems removing rotor
Old Nov 17, 2007 | 12:59 PM
madridlover's Avatar
Default Problems removing rotor
I have a 98 2.8L and my driver's side rotor will not come off. I've done the passenger side already and it just fell off. I've sprayed the crap out of it with PB Blaster and nothing.
Is there something I'm missing?????
My next step is to try a crow bar. Any suggestions?????
Old Nov 17, 2007 | 01:46 PM
auditech79's Avatar
Default RE: Problems removing rotor
Hit it back and forth with a hammer on both sides of the rotor until you break it loose. I've had to break out a 5 lb sledge hammer for rotors before.
Old Nov 17, 2007 | 04:28 PM
EnviedA6's Avatar
Dido, you may just have rust or corrosion causing the rotor to stick to the axel.
Old Nov 18, 2007 | 01:57 AM
Cmoney's Avatar
I sprayed WD-40 all around the rotor, let it set for a few minutes and tapped it on top a few times to remove it. Good Luck.
Old Nov 18, 2007 | 04:46 AM
nihil's Avatar
Recently did all four corners on mine, and had to take a hammer to one of them for a couple minutes before it would budge. You didn't mention if you were doing front or rear, but if you're doing rears, be sure to get the specialized tool that turns the pistons when it compresses them. I thought I could get by without, but really there is no sane way around that one.
Old Nov 18, 2007 | 11:48 AM
Thanks guys for the responses. I finally got it off. After spraying it all over with PB Blaster, hitting it with a mallet, hitting it with a hammer, taking a lunch break so the blaster would have more time to soak in, and hitting it again with a hammer it finally came off.
I did the fronts only and replaced the rotors with Brembo rotors and the pads with Akebono Euro Ceramics. The breaks feel a lot better and I know from putting Akebono's on my Bimmer that the days of brake dust on my rims are all over [8D].
Old Nov 18, 2007 | 01:20 PM
nihil's Avatar
No more brake dust you say? I'm interested and wish to subscribe to your newsletter.
Any more info on these miracle pads? Are they noisy?
Old Nov 18, 2007 | 07:00 PM
Not noisy and leave no dust. Check out the reviews on www.tirerack.com or look for more info here: www.akebonobrakes.com
dailybeast
Sep 11, 2011 12:22 AM
sa9023
Oct 14, 2010 09:52 AM
monsterhunter
Oct 14, 2007 01:16 PM
DBK123
Oct 9, 2007 12:20 PM
AML 225
Jan 11, 2007 04:13 AM
