Rear third brake light
Old Dec 18, 2007 | 07:35 PM
MiniSpdRcr's Avatar
Default Rear third brake light
I have a bulb out in the rear third brake light. I was wondering how one goes onto replacing it?
Old Dec 18, 2007 | 08:27 PM
auditech79's Avatar
Default RE: Rear third brake light
The little LED's aren't worth the time to replace. Every time i try to replace one of the bulbs one or more goes out again. Just replace the entire bulb strip.
Old Dec 18, 2007 | 08:40 PM
MiniSpdRcr's Avatar
Hm...how do I get it out...and where could I get the whole strip?
Old Dec 18, 2007 | 10:54 PM
prbayha's Avatar
You dont replace the strip, you replace the LED bulbs. If one goes out they all should be replaced. Get in your trunk and uplug the green clip which is the wiring harness. Push up and out and the clips will let loose and the part literally falls into your lap. There are 2 plastic clips on each end opposing one another. Carefull pry the large end up with a small flat blade screwdriver and the front lense (red) will come off. Then, simply pull each bulb straight out and replace. They are a $1.50 at the dealer a peice and ifI remember there are around 9-10 bulbs. Reverse procedure and you are done. The bulbs, if replaced one by one, will keep buring out because lower voltage caused by the burnt out bulb causes premature wear so when you plug a new bulb in, theincrease in voltage across the string causes multiple bulbs to fail over time.
Old Dec 18, 2007 | 11:31 PM
MiniSpdRcr's Avatar
Do I just do this from inside the trunk? I looked and it seemed like a small hole...hm.
Old Dec 19, 2007 | 06:54 PM
prbayha's Avatar
Back into the trunk belly up. As soon as you clear the inner trunk lip, look up...it sits right there..You can't possibly miss it.
Old Dec 20, 2007 | 09:01 AM
NH_USA's Avatar
What happens if he has a big German Beer belly?
Old Dec 20, 2007 | 09:18 AM
MiniSpdRcr's Avatar
Nope...no German Beer Belly on me. heh, just wanted to make sure that I will do it right
Old Dec 20, 2007 | 04:57 PM
MiniSpdRcr's Avatar
OK...I cannot get this danged light out...my wiring harness is on the right side of it and its not acessible for me. I tried pushing up and out on those metal clips...but nothing happens. So...have no clue
Here are some photos...maybe someone can outline what I need to do.
Old Dec 22, 2007 | 08:17 AM
MiniSpdRcr's Avatar
