rear window switch
well child safety is off and also windows is no locked.
but rear window switch on rear doors are not working.
what should I check on this?
it works from front switch but not from rear.
Hold down the rear window lockout button while someone tries to activate them in the rear.
90% chance it will only work when your holding down that button on the master switch. If they work when someone is holding the lockout button you need a new master window switch.
ORIGINAL: nemiz
And then? If you ask me to play with the wires - I must tell u I'm colour blind.
ORIGINAL: auditech79
There is a small hole on the bottom the handle on the door, use a small pocket screwdriver and push the switch up through that hole.
I'll see if I can take that part and see how connections are.
I looked at the pic from the parts and looks like easy opening that one out and check.
prob contact is worn and not making connections I assume. since when you press it all the way it works.
I had the same problem and I had my switch changed. I was getting some warranty work done and since I was already paying the money, I just had them add that on. I works fine now. Good luck. I have a 2000 2.7
