rear window switch
Old Sep 25, 2007 | 07:20 PM
tahoehtp's Avatar
Default rear window switch
well child safety is off and also windows is no locked.
but rear window switch on rear doors are not working.
what should I check on this?
it works from front switch but not from rear.
Old Sep 25, 2007 | 07:25 PM
auditech79's Avatar
Default RE: rear window switch
Hold down the rear window lockout button while someone tries to activate them in the rear.
90% chance it will only work when your holding down that button on the master switch. If they work when someone is holding the lockout button you need a new master window switch.
Old Sep 25, 2007 | 07:28 PM
tahoehtp's Avatar
I just checked it and yes that was it!
well I'll see if I can take that master switch out and clean... and see what happens.
Old Sep 25, 2007 | 07:35 PM
nemiz's Avatar
MMM...Nope I tried ur method.......still not opening!
Old Sep 25, 2007 | 07:41 PM
auditech79's Avatar
There is a small hole on the bottom the handle on the door, use a small pocket screwdriver and push the switch up through that hole.
Old Sep 25, 2007 | 07:45 PM
nemiz's Avatar
And then? If you ask me to play with the wires - I must tell u I'm colour blind.
Old Sep 25, 2007 | 07:50 PM
auditech79's Avatar
ORIGINAL: nemiz
Do both of your rear window's not work? If so just replace the master window switch anyway, there isn't anything else that will cause both rear window switches to notwork.
Old Sep 25, 2007 | 07:57 PM
nemiz's Avatar
Sounds logical.
i'll try that!
Thank u
Old Sep 26, 2007 | 01:21 PM
tahoehtp's Avatar
ORIGINAL: auditech79
so it's just pop out? and disconnect cable correct?
I'll see if I can take that part and see how connections are.
I looked at the pic from the parts and looks like easy opening that one out and check.
prob contact is worn and not making connections I assume. since when you press it all the way it works.
Old Sep 29, 2007 | 04:13 AM
Cmoney's Avatar
I had the same problem and I had my switch changed. I was getting some warranty work done and since I was already paying the money, I just had them add that on. I works fine now. Good luck. I have a 2000 2.7
