remote key fail
Old Jul 17, 2009 | 10:50 PM
blackys's Avatar
Default remote key fail
Hi,
I have a 2000A6 2.8q. Recently I found out my remote key can't work and also I can't lock the car from inside using the lock button on the driver's side door. I guess the electronic module is broken or the wire conection is dead. Can anyone give me some advices to diagnose it or fix it.
Thanks very much.
Old Jul 20, 2009 | 11:03 PM
s31523's Avatar
As far as I know the car will not lock when the drivers side door is open. Your keyfob might need to be re-syched with the car. Look it up in your owners manual. If you don't have one search the threads on here.
Old Jul 21, 2009 | 10:49 AM
Jackmup's Avatar
Try replacing your fob battery then go out to the car put the key in the door unlock it with the key and then press then unlock button on the fob. See if that helps.
AudiGirl92
B7 Models
Aug 31, 2013 08:28 AM
MartinCieslak1
Dec 11, 2009 02:30 PM
krshrk
B8 Models
Sep 18, 2009 07:08 PM
blackys
Jul 18, 2009 11:17 PM
marcink99
Jan 26, 2008 10:09 PM
