Service Interval Reset
Old Mar 27, 2010 | 06:30 AM
staglad's Avatar
Default Service Interval Reset
I want to be able to reset the service indicator on my 2006 A6 and know that I need a VAG-COM cable to reset it with.
Does anyone know if it is possible to reset the service indicator with the VAG Commander v1.4 software in anyway?
Old Mar 27, 2010 | 04:59 PM
jhuffman's Avatar
I don't think that you need a vag to do it, but you should be able to. I reset mine by holding the trip timer button for a few seconds then starting the car and holding it for a few more seconds.
Old Mar 27, 2010 | 05:51 PM
Kevin's Avatar
You have a C5. The OP has a C6 and does need a VAGCOM to restet the service indicator.
Old Mar 27, 2010 | 06:26 PM
jhuffman's Avatar
oh bummer. A vag com is a good tool to have around, I'd just get one.
Old Mar 27, 2010 | 06:27 PM
NH_USA's Avatar
It's a C4 not C5 or C6!
Pressing the trip reset button does not work.
I haven't figured out how to do it with VAGCom.. but maybe someday!
Old Mar 28, 2010 | 05:21 AM
staglad's Avatar
I know it's built into the newer VAGCOM Commander software v5 onwards but wondered if it was possible with version 1.4.
The other one is does anyone know if the VAGCOM Commander USB cable works with ross-tech software. I think the ross-tech software looks specifically for it's own cable drivers but wondered if it will work with another cable instead.
Has anyone done this?
Old Mar 28, 2010 | 07:52 AM
Kevin's Avatar
The OP has a 2006; it is a C6.
Old Mar 28, 2010 | 10:03 AM
histeel's Avatar
There is a way to reset your c6 with the vagcom . research it on the ross tech site, if the options dont come up you need to do a map search of your modules and send them to ross tech and they can send you the file that will open these options.
jamesfreeman86
Dec 2, 2008 02:02 AM
Southern6er
Jun 1, 2008 09:06 PM
drake008
Jan 13, 2008 04:00 PM
maciej
May 11, 2006 09:10 PM
dudley doright
Mar 14, 2005 02:18 PM
