Service Light
Old Nov 3, 2006 | 08:03 AM
mullerps's Avatar
Default Service Light
Hi all just wondering if anybody knows how to switch the service light off rather than going to a garage
Old Nov 3, 2006 | 08:17 AM
techbod's Avatar
Default RE: Service Light
button A is the odometer under the speedo and B is the dimmer under the rev counter.
OEL-OIL service light
press and hold button A,
switch ignition on,
release button A,
the letters OEL or OIL will appear in the odometer display of the speedometer.
pull out button B until the letters are erased and replaced by *--*
that's the oil service light reset..
now the inspection service light.
press and hold button A.
switch ignition on.
release button A.
the letters INSP will appear in the odometer display of the.
if required clear the OEL-OIL indicator from the display as previously described
Old Nov 3, 2006 | 05:22 PM
beefski's Avatar
Dave, my 1996 A6 Avant has a service indicator on it is 1n1. What does the code mean? Is there a way to reset?
Thanks.
Oh btw, glad you are not dead.
Old Nov 3, 2006 | 05:27 PM
techbod's Avatar
basically its a timer issue and nothing to worry about but ill look the rest data up
Old Nov 3, 2006 | 05:38 PM
techbod's Avatar
shorting pins 4/5 and 7 with a 1k ohms resistor resets the system, 4 is the ground 5 is the ground shield 7 is the K line so while the resistor is inserted between the pins it checks the system then when you turn the ignition off and back on within 15 seconds it checks and clears the last codes and so on airbags/abs/engine codes
Old Nov 3, 2006 | 05:40 PM
techbod's Avatar
pin 4 is the ground and pin 5 is the ground shield so either will serve as a ground
Old Nov 3, 2006 | 05:47 PM
techbod's Avatar
[IMG]local://upfiles/12092/8394417AD0904EEDA6316B646D9C9409.jpg[/IMG]
Old Nov 3, 2006 | 05:52 PM
techbod's Avatar
you have to keep the ignition on for 4.5 seconds for each system check and clearing
Old Nov 3, 2006 | 07:58 PM
beefski's Avatar
Thats a lot of things to do just to clear a service reminder.
Will a VAG be able to do it? If so where, because I had somebody VAG the car a while ago and could not figure out how to clear the service reminder. Also what is the 1n1 saying needs to be serviced?
Old Nov 17, 2007 | 09:27 PM
rmknox's Avatar
Dave's button kabuki dance procedure above worked on my 98 A6 2.8 Quattro for both the OIL and the INSP reminders when the procedure on the other threads did not. Thanks.
Truthteller
May 2, 2008 10:20 AM
Lena
Dec 15, 2006 09:59 AM
impaler2383
Dec 8, 2006 06:10 PM
Rikter
Aug 20, 2006 08:48 PM
audisales
Sep 7, 2004 12:15 PM
