slight vibration
Old Sep 1, 2010 | 10:57 AM
alxjhn's Avatar
Default slight vibration
i have a 2001 a6 4.2. i got a slight vibration above 35mph...brand new tires and road force balancing and alignment done.. control arms are good and brand new tie rods... what could be wrong???????
Old Sep 1, 2010 | 11:12 AM
myriadshalaks's Avatar
motor mounts?
Old Sep 1, 2010 | 11:24 AM
TwinTurboC5's Avatar
Default Slight Vibration
Ever consider that maybe your brake rotors are warped?
Old Sep 1, 2010 | 03:54 PM
oldmots's Avatar
Possible that the balancing was poorly done, I have had tires rebalanced and gotten rid of vibrations more than once. Even good machines can be out of spec.
Old Sep 1, 2010 | 04:05 PM
NH_USA's Avatar
Crappy tires -- I once had a set of new tires that balance perfectly and there was a vibration that would not go away. They changed all four tires without fixing the problem so I had to live with it - They were not cheep tires....
A few years later I put new tires on the car (different brand)and the vibration want away.
Old Sep 6, 2010 | 10:40 AM
alxjhn's Avatar
Default vibrations
the vibration increases when i take turns at above 45mph..the tires are directional tires
Old Sep 6, 2010 | 01:35 PM
ninetynineA6Q's Avatar
I had a similar problem with my wife's car when the front axles wore out. When the joints get sloppy, they can cause all sorts of interesting vibrations.
Old Sep 6, 2010 | 10:49 PM
Jackmup's Avatar
Where exactly are you feeling the vibration? Steering wheel, Seat, pedal...
My steering wheel wobbles slightly sometimes and sometimes not. I think it is control arm related.
The Engine mounts vibrated through the brake pedal at a light then go away under acceleration.
Warped rotors will feel worse when you step on the brake pedal.
guscenter
Audi Q5
Apr 10, 2015 01:58 PM
divingmoose
Nov 27, 2012 02:46 AM
alxjhn
Apr 16, 2010 02:55 PM
B7Night
B7 Models
Dec 5, 2009 06:51 PM
markosky
Oct 5, 2009 05:03 PM
