slow wipers
I've got a A6 3.0...2002. Sometimes after little use, my wipers are very slow. Even when I move them to high speed they are slow. Eventually they speed up, but I'm concern that I'm on the verge of a failure. Any familiarity w/ this issue?? Is it a known problem?
Thanks, |
Usually means the wiper linkage is getting corroded. Not sure what it takes to remove it and lube the joints, but that should be your first action. Could also be a motor going bad.
Bob |
I agree. Sounds like the linkage is corroding in the joints and stiffening up. If it has too much resistance it will start popping fuses. I never had to change it on the audi, but it was fairly simple on my old tiburon.
