Something scratching my window
Old Oct 2, 2008 | 04:26 PM
Stone825's Avatar
Angry Something scratching my window
Hey guys, I just noticed today that on the drivers side window there was some sort of sound coming from it as it went up and down. As I soon learned, the sound was the sound of something scratching my window as I put it up and down. I'm not sure what could be in there but I have a thin long scratch in my window now.
How hard is it to get something out of there and what kind of tool should I use?
Old Oct 2, 2008 | 08:11 PM
2001A6's Avatar
are you sure is actually scratching it? my pass window is noisy, makes a grinding sound but it no longer makes marks. It used to leave two parallel marks up the window, looked like scratches. I was worried it would mess up my tint when I got it but I tried cleaning the inside of the window and it came right off, it was just grease.
Old Oct 2, 2008 | 09:13 PM
djez016's Avatar
my window made similar sounds it turned out to be that rubber stripping at the bottom of the window it had hardened some i scrape some of he hard rubber back and wiped i with tire shine with a silicone base and i have not heard the sound since
Old Oct 2, 2008 | 10:39 PM
Stone825's Avatar
Thanks guys, that is probably what it is. Sorry but I'm kind of uptight about the car because I just got it and hopefully getting a chip in 2 weeks
Old Feb 10, 2009 | 10:04 PM
astrobill's Avatar
All:
The passenger side glass on my 2008 A4 has ACTUAL scratches on the outside.
QUESTIONS:
1. Are most people getting the scratches on the OUTSIDE or on the INSIDE?
2. On which side(s) of the door glass does any mechanism touch the glass?
Here's why I ask:
I took my car in for this, and Audi of Rockville, MD claims there are no mechanical devices that touch the outside of the window that could cause scratches of any kind, reinforcing their "debris" theory. They said they "blew it out" and there's no debris in there now.
HBL Audi of Tysons told me this is "very rare"...is that true? Seems like a lot of people are finding this.
BP
Old Feb 11, 2009 | 02:58 AM
chefro's Avatar
It shouldn't be any mechanical device/part that comes in contact with the glass itself, exactly as the dealer stated.
However, if your plastic guide(s) is (are) broken and the cable doesn't glide through its channel (jumped over), it is the possibility that it may rub against the window.
On older models, the regulator attaches to the window via a big plastic retainer/fastner:
On newer models, the regulator attaches to the window via 2 small plastic "guides":
You be your own judge as far as what mechanical part can rub against the glass.
Lliamtheunmerciful
Feb 6, 2011 06:33 PM
ImTheDevil
Feb 2, 2010 09:03 PM
csx4780
Nov 23, 2007 11:30 AM
theTTkid
Jun 1, 2007 11:32 PM
KevinA4
Nov 1, 2006 12:42 AM
