Speedbleeders?
I've used these on my motorcycles, which makes replacing brake fluid much easier. I can't find ones for an A6 . Any idea the dimensions of the bleeder valve on a C5 A6.
They have a check valve built in to keep the air from returning in when loosened. Makes bleeding brakes a one man operation. |
RE: Speedbleeders?
I was able to find the answer to my own question.
Front....SB1010S Rear.....SB1010S They are definitely worth checking out if you plan to bleed your brakes. |
