Standard Features
Sup guys.
I do want to ask this question. I got a 1998 Audi A6 Quattro v6 30v I want to know what standard features this car has? I know the following 1) Front Driver & Passenger Airbag 2) Driver & Passenger Side Airbag 3) Front to rear side curtains Airbag 4) ABS 5) All-Wheel-Drive (coz it's Quattro) 6) Does it has Traction Control as standard? 7) Is ESP the same thing for Traction Control? is it standard? 8) Immobilizer? 9) Alarm system like motion sensor? etc? Thanks all. I really don't know what I have. coz I never see the ESP icon on my dash, never see the Key icon either. and I never see many lights on my dash except, Check Engine, Airbag, ABS, Brake, Battery, and Seatbelt. Also, when I use Cruise Control, no Cruise icon on the dash either. is that normal? Or just that alot of the BULBS in the dash is out?? Thanks all. |
RE: Standard Features
go to audiworld.com and go to the model guide for details.
It only gives the specs for a 2004 Audi A6.
I need the specs for 1998 Audi A6 2.8L. Thanks alot. Anyone else with info? |
ESP = Electronic Stability Program, this is a bolt on feature like ABS and traction control but with added ESP it makes the perfect system for safety and car control.
1998 a6 specs. http://www.internetautoguide.com/car.../1998/audi/a6/ |
EPC on the other hand, view topic;)
http://www.audi-forums.com/t4132-a4-...power-loss.htm |
Not 100% sure but this is my educated guess.
1 standard 2 option 3 option 4 standard 5 standard 6 option 7 option yes 8 didnt think that was avaiable till 2000 in us. Do you have a car with a key on it that lights in the dash? standard if equiped 9 standard |
From what I see in http://www.internetautoguide.com/car.../1998/audi/a6/
I think it's for Euro style A6. And it said 1998 Audi A6 Handling, Ride & Braking Standard Features - ABS - 3.409:1 axle ratio - Front differential lock - Four disc brakes including two ventilated discs - Electronic traction control via engine management - Immobilizer - Spacesaver steel rim spare wheel - Multi-link front suspension with stabilizer bar independent with coil springs , torsion beam rear suspension with stabilizer bar independent with coil springs So my car do have ABS and ESP, but immobilizer is only for Euro until 2000 in USA correct? I have 2 questions guys: 1) If I do have ESP, (that triangle with ! in the middle icon) don't I see that icon lights up in my dash when I first start my car?? 2) Do you guys have Crusie Control Icon on the dash when you are using cruise control on highway?? Thanks alot guys. Gil |
