Starts hard on first try
I have a 2005 A6 3.2, Like he title says If the car sits for awhile (a couple of hours) and you go to turn it on it takes it 4-5 seconds, if you try again it starts right up. Sometimes on the first try it will start but shudder and shut off. I'm not sure if anyone has had the same issue or not, any help would be greatly appreciated.
generic scanners will give random misfire codes or something else vague in which u will have to use deductive reasoning to figure what the problem is. Vag-com will tell u exactly which cylinders are misfiring(bad coil, bad spark plug, bad icm), if one of the coolant temp sensors are faulty and which one as well as the readings they are giving in real time. it can tell u whether ur fuel is too lean during idle despite the ecu trying to increase it (fuel filter, or fuel pump).
daboss085
10-18-2012 11:43 AM
audical
01-10-2008 06:47 PM
