steering problem
Old Feb 1, 2005 | 02:57 AM
mitao2000's Avatar
Default steering problem
hi sometimes when pulling into parking lot the steering wheel it's really hard to handel it's really hard ,but after you stop the car and try to steer left right it's going really easy it's like i notice the faster you go the steering wheel become harder and harder and when you slow and try to take sharp turns it looks like the steering wheel it's stuck in the same mode like you are doing 70mph.anybody any ideeas.thanks
Old Feb 1, 2005 | 02:59 AM
mitao2000's Avatar
Default RE: steering problem
and sorry the car is an A6 4.2 from 2000.thanks
Old Feb 7, 2005 | 09:37 PM
mitao2000's Avatar
anyone that could help me?thanks
Old Feb 8, 2005 | 12:54 AM
Jestnomen's Avatar
6th Gear
have you checked the power steering fluid level?
Old Feb 8, 2005 | 01:44 AM
slee22's Avatar
What about the Servotronic Relay (number 605)? It's under the panel under the steering column. There are two 8mm hex bolts holding the panel on, and the relay is located left of the steering column. When the relay is removed or maybe in your case if its bad, it will tighten the steering quite a bit.
Old Feb 8, 2005 | 03:22 AM
mitao2000's Avatar
the power steerin fluid it's a max level but the relay i don't know how am i suposed to know if it's defective?thanks
Old Feb 8, 2005 | 02:41 PM
slee22's Avatar
I guess try a new one.
bringamac92
Jan 13, 2011 12:19 PM
gold2734
Sep 3, 2009 08:58 PM
Lastb0isct
Feb 17, 2009 03:15 PM
99'A6
Sep 26, 2008 08:35 AM
B5nightrider
Oct 3, 2005 03:34 PM
