Still Missfiring,Vag-Com Help??
Hi All,
I Still Have Missfiring on My 99' Audi A6 2.8.
I Changed The Coolant Tempatur Sensor Still Have The Same Problem.
I bought the USB vag-com. So Hooked The Up And Read For Codes and i find Code 16684 and 16688,
I Looked ander Measuring under group 16 and say i have 15 missfiring on zylinder 3, 12 under Zylinder 4.
i Claerd All Codes And Drive Again And Read Again under measuring Goup 17 Missfiring now under Zylinder 4 and 5, No Misfiring under Zylinder 3.
Anybody have Any Suggestion.
Maybe a Bad Coil Or A Bad Ignition Controll Module?
And I Still have White SPark Plug. Whats This Mean?
Thx Torsten
Thx Torsten
RE: Still Missfiring,Vag-Com Help??
Hi I think I Find The Problem.
I switch The Spark Wire Around. Wire 4 to wire 3 and start missfiring on zylinder 3, zylinder 4 its fine.
So I think I need a Set Spark wires.
But Big Thx On This Site And On This Members in this Forum.
Thx Torsten
Thx Torsten
Oh you have the2.8L, im sorry the 2.7T has external power output stages or (ICM's), you have integral power output stages inside the three ignition coils on the front of the motor. So i would say the ignition wire that you swapped would be the correct diagnosis.
