Suggestion on Exhaust for 2.7T
RE: Suggestion on Exhaust for 2.7T
Borla, magnaflow, remus, are all good manufactures, or you can get it custom made.
If going custom made just make sure not to get larger than 2.5 inch pipe because that would be a little too big for stock k03 turbo chargers.
Try Vast piggie pipes...best bang for the buck and helps prolong the life of your turbos http://vastperformance.com/shop/prod...products_id=65
with the piggy back whats the difference between the stock one? do they gut the cats or something?
what is the stock tubing size on the 2.7T?
What part of a S4 exhaust can be used on the A6? Does the downpipe off a s4 work on a a6?
What is done to a Stage 2 A6 like this one? is it only exhuast?
http://www.youtube.com/watch?v=gIe1ROTRBzs
I have heard that clip and think it sounds pretty good. I wish we had some other (good) sound files from the outside of the vehicle. I would like to hear:
[ol][*]magnaflow catback on otherwise stock 2.7T.[*]magnaflow with piggies[*]same as 1 & 2 with borla[*]same as 1 & 2 with APR[*]plus other set ups i.e Milltek etc.[/ol]
Any exhaust that is designed to fit the A6 can be altered for personal preferences, but if you are looking to purchase either a cat-back or a turbo back system and leave as is, I personally think that either APR, Miltek or Supersprint is the way to go.
I customized my exhaust matching APR downpipes with a Miltek cat-back. I cut out my central resonators and welded in straight tube stainless steel. The sound is awesome!
OOOO
OOOO
HI Joeski, can you post a video or sound clip?
I have VAST Piggies and APR Catback, it sounds like stock!!!
I want to remove the resonator and replace with it straight pipes like yuo... just curious of what it might soundlike, I don't want my car to be too loud either.
