TDC Mark
Old Mar 13, 2007 | 02:33 AM
wings7351's Avatar
Default TDC Mark
I'm about to change my timing belt, trying to put the engine at TDC. Everybody is talking about a TDC mark on the crankshaft pulley, but I just can't find any obvious mark on the shaft or on the pulley. Can anyone help? Mine is a 99 A6 2.8 30V
Thanks..
Old Mar 13, 2007 | 04:39 AM
auditech79's Avatar
Default RE: TDC Mark
Look harder man its there, use a good flash light and rotate the engine over by hand until you see that notch on the crank pulley, when you do use some white out on it so you don't lose it again.
Old Mar 13, 2007 | 03:13 PM
wings7351's Avatar
Auditech79, so it is on the pulley, not the shaft, right? would you have a picture of it? Thanks.
Old Mar 13, 2007 | 03:33 PM
techbod's Avatar
[IMG]local://upfiles/12092/F1D1A240771A47B0A72229896289C181.jpg[/IMG]
Old Mar 13, 2007 | 04:39 PM
prbayha's Avatar
Use a timing light and some white out to mark TDC. Should be fairly easy to read with the light.
Old Mar 13, 2007 | 04:47 PM
techbod's Avatar
timing light is only useful when the engine is running and as its a refit of new parts this is not practical ( not that you could do anything even with it because its computer controlled ) the timing that is, fitting a new timing belt is a static thing ( remove and replace )
Old Mar 13, 2007 | 05:01 PM
prbayha's Avatar
true..I didn't think that the engine wasn't running due to the T-Belt ...duh..DISMISS ADVICE!
love the booB5
Apr 16, 2009 06:08 PM
Drfeelgood69247
Nov 11, 2008 08:14 PM
suhayb
May 3, 2008 04:29 PM
newyorkgiants44
Apr 20, 2007 06:40 PM
